VHDL : function not recognizing a type defined in package
Started by jmca 6 years ago1 replylatest reply 6 years ago395 views
I am trying to write a function that reads from csv file and formats data to fixed point so it can be used to initialize ROM contents.
The function is contained in a package. The package body looks like:
-- Package Body Section
package body file_io_pkg is
impure function f_init_rom_fixed
   ( fname : string ;
     path  : string;
     fsize : integer;
     int_size : integer;
     dec_size : integer  ) return t_sfixed_vec is
variable v_csv_file    : csv_file_reader;
variable v_read_sfixed : t_s16 ;
variable v_sfixed_vec  : t_sfixed_vec;
   v_csv_file.initialize(path&fname);
   v_csv_file.readline;
   l_read:
      for i in 0 to fsize - 1 loop
         v_read_sfixed  := signed(to_sfixed(v_csv_file.read_real, int_size ,- dec_size);
         v_sfixed_vec(i):= v_read_sfixed;
      end loop l_read;
   return v_sfixed_vec;
end function ;
end package body file_io_pkg;
I get the following error when elaborating :
Error : 'csv_file_reader' is not declared (VHDL-1241) : C:/FPGA/test_prj/hdl/file_io_pkg.vhd(54)
But csv_file_reader is a type defined in csv_file_reader_pk (https://github.com/ricardo-jasinski/vhdl-csv-file-reader)
This package is compiled is imported at the library section of my package.
library work;
use work.csv_file_reader_pkg.all;
So I can't really see why I am getting this error, any hint?
Thanks in advance
Reply by adouvilleJanuary 8, 2020
The type defined into your package (csv_file_read_pk) is csv_file_reader_type (not csv_file_reader)...
