Inverse Transform Sampling method on FPGA
Started by Bobby29999 6 years ago3 replieslatest reply 6 years ago117 views
I am working on pseudo random number generation topic. To be precise,  Inverse Transform Sampling method , i.e., a method for generating sample numbers at random from any probability distribution given its cumulative distribution function.
The problem that the inverse transform sampling method solves is as follows:
- Let X be a random variable whose distribution can be described by the cumulative distributive function Fx.
- I want to generate values of X which are distributed according to this distribution.
 The exact reference of what I would like to implement on FPGA is : https://en.wikipedia.org/wiki/Inverse_transform_sa...
Questions:
- What would be the mathematical challenges? I mean challenges in context of natural log and then data types like integerfixed  and floating points.
- What should be the right approach? I mean the starting point.
I am looking for some example codes (if any) and helping literature that would help me to understand the granularity of implementation on FPGA.
Looking forward to suggestions. Thanks a lot !
Reply by kazApril 7, 2020
Here are my initial thoughts
1) You can precompute your chosen CDF and insert it in a look up table. This will reduce a lot of run time computations.
2) You then generate runtime initial random numbers say from shift registers with feedback taps and assume they are in the range 0-1 e.g a 16 bit shift register will generate numbers between 1 and 2^16 then you can assume the ratio as the generated number relative to 2^16
3) use the generated numbers to address the look up table. The content will be your inverse sample.
Reply by Bobby29999April 7, 2020
Kaz it was a helpful reply... I have posted another question on the forum. Can you also please help me in that question. Here is the link: https://www.fpgarelated.com/thread/10860/
