A user seeking a WYSIWYG alternative to CircuiTikz for creating block diagrams for personal projects received several recommendations for both open-source and professional software. While Microsoft Visio remains a professional favorite, the community highlighted several capable free and lightweight alternatives suitable for Windows and Linux.
- Draw.io (diagrams.net) and yEd Graph Editor were highly recommended as versatile, free tools for complex diagrams.
- Dia and Inkscape are suggested as the best open-source Linux alternatives to Microsoft Visio.
- PlantUML and ASCII editors are noted as efficient options for users who prefer text-based diagramming over traditional GUI tools.
- For simple documentation, internal drawing tools within office suites like LibreOffice Draw or PowerPoint are often sufficient.
Hello everybody,
I am searching for a WYSIWYG software to draw, from complex to simple, block diagrams for documenting my personal projects.
So far I am using CircuiTikz for LaTeX, has good results, but laborious to achieve them, in terms of time.
Known good options so far:
- - Microsoft Visio (paid, somewhat affordable)
- - Sigasi Studio XPRT (paid, not affordable)
Any open source or paid (affordable) recommendations (Windows, Linux) would be very welcome. :)
Rafael.
Hi Rafael,
Its an interesting question. You could use the yEditor. Pls Google it. It is the best and free! software out there. I have used it extensively last 10 years and am very satisfied. Pls note it is updated continuously. Very spectacular block diagrams can be made with yEditor.
You can use tools like:
- draw.io
- Edraw
- Visual Paradigm
- Enterpise Architect
Can't really tell from your question, and your option list, whether you're looking for block diagram software, circuit diagram software, or some integrated code/schematic editor?
On Linux the closest replacement to Visio is dia. Another option is inkscape. Both export to eps if you're using LaTeX for the rest of your documentation.
For just schematic diagrams there's diagramming tools like xcircuit up to full schematic/board layout tools like Kicad.
Hi Rafael,
I've used various versions of Visio and it works quite well for basic block diagrams and flow diagrams. But yes it does cost a bit and since is was purchased by Microsoft it lost the simplicity that made it such a nice tool when I first started using. Recently I've used
If your block diagrams are relatively simple you can use the drawing features in Word, Excel or PowerPoint to reasonable effect. They're all a bit different and I use them for slightly different purposes. Don't use them for large diagrams but for basic state machines, block diagrams they're fine.
You can also try OpenOffice Draw, I found it recently and its actually pretty good at doing flow charts (comparable to Visio before Microsoft). I also use it to draw the layout plan for my garden.
The only time I'd consider using a CAD tool as mentioned is if the diagram is really big, and if its that big you're probably doing wrong.
Lastly if you want to do a diagram really fast the best method is to draw it using a pencil or a whiteboard and take a picture. Then import the diagram in Word, Excel or Powerpoint (or whatever you use) and overlay any arrows or call outs you want to annotate the picture. Works well and can actually look good. If you do pencil I recommend using graph paper with faint lines looks nice and if the lines are blue the they almost disappear.
And lastly I use program editors to make diagrams using ASCII characters, and this is actually my favourite method.
Cheers.
PlantUML is an interesting program from generating UML diagrams from a basic markup language. It even has a visual Studio Code plugin.
I also tried and liked Software Ideas Modeler. It has a nice GUI and I found it more intuitive than most UML tools. It’s not free, though a license doesn’t seem too expensive
I've been using Visio for longer than I care to remember (must be more than 20 years) and I love it!!!
There really isn't a good open source cad tool designed for the work that system architects do.
Anybody want to help create one?
maybe umbrello -
https://umbrello.kde.org/
its designed for uml - but maybe it is working for your usecase..
id did some uml dokumentation some time back for a projekt and it did work nicely..
other idea:
inkscape has a diagram connector type - it helps in that the line is automatically adjusted if you rearrange the nodes...
but in general a lot more work and more possibilities in design ;-)
Depending on the task or the kind of drawing I needed, I'd used the same as others recommended:
- draw.io
- yEd
and also one that was not recommended yet:
- DIA
Thanks for all the replies and suggestions, I shall take a look at them. As some suggested, Visio is a great tool, I use it professionaly. For private use I tend to use opensource tools due to its flexibility and price. The money I can save on software, I can invest on hardware. :)
Cheers.
