TinyFPGA BX Creating Two OR Gates
Started by Joe3502 6 years ago1 replylatest reply 6 years ago180 views
First off, I hope that you and your families are staying safe and well during this time of global pandemic.
I just received my TinyFPGA in the mail yesterday and I need to create two OR gates for a project to start out with. I made the code for them using what I have already learned, but I am not sure how to define my inputs and outputs to specific pins on the TinyFPGA itself.
Here is the code that I currently have:
Thank you and stay safe,
Joe M
Reply by mon2July 30, 2020
Hi Joe. Also learning the ropes with FPGA programming using Verilog. Using the Lattice toolchains and reporting the never ending errors in their documentation in the process.
On your (old) post, you need to create yet another text file that will be the constraint file. Inside this constraint file, you will map your input / output pins to physical port pins for the FPGA package you are planning to use on your kit.
We recently closed a design with the Lattice ICE40UL1K (8 pin DIP size) and had a similar learning curve.
Using ICECube2 for our development on Windows.
Here is the output from our PCF file for a recent project (as an example):
# iCEcube PCF
# Version: 2017.08.27940
# File Generated: Jul 14 2020 10:52:20
# Family & Device: iCE40UL1K
# Package: SWG16
###IOSet List 1
set_io rgb0 B4
set_io rgb1 A4
set_io rgb2 C4
set_io pushbutton A1
set_io bar_code_pin A2
