Doubt about constraining external input
Started by simonzz 6 years ago●4 replies●latest reply 6 years ago●194 views
Summary A user inquired whether timing constraints like input_delay are necessary for the AD9914 DDS DROVER signal when sampled by a Xilinx UltraScale+ FPGA.
A user inquired whether timing constraints like input_delay are necessary for the AD9914 DDS DROVER signal when sampled by a Xilinx UltraScale+ FPGA. The discussion clarifies that since the signal is asynchronous and non-deterministic relative to the FPGA clock, standard setup and hold constraints are not applicable.
The conclusion suggests that while traditional timing constraints are not required for asynchronous inputs, proper synchronization techniques like edge detectors or FIFOs must be employed to prevent metastability and ensure the signal is captured correctly.
  • Input delay constraints are generally reserved for synchronous signals where setup and hold times relative to a reference clock are known.
  • Asynchronous signals do not require input delay constraints but must be handled via synchronization circuitry.
  • The AD9914 DROVER signal's pulse width must be long enough to be reliably captured by the FPGA's sampling clock.
  • The user implemented an edge detector to safely synchronize the DROVER signal to the FPGA clock domain.
Timing ConstraintsFPGA DesignClock Domain CrossingDDS Interfacing
I am usig an AD9914 DDS
https://www.analog.com/media/en/technical-documentation/data-sheets/AD9914.pdf
with its DROVER output connected to a I/O of the FPGA device (UltraScale+), used to signaling digital ramp as shown below:
Since this is an asynchronous non deterministic input signal, is it necessary to set timing constraints (e.g. input_delay) for the DROVER input to the FPGA ?
As far as I understand, input delay constraints make sense when setup and hold time with respect to a reference clock is known, input data and clk are running at the same frequency, but in this case the DROVER input is sampled at a frequency high enough to detect it. Would still make sense applying constraints ?
Thanks.
s.
Reply by kaz●February 27, 2021
The question should be: can the fpga input DROVER be asynchronous? I doubt it since it could be as short as one clock period of DDS yet needs to be seen by fpga. Thus you need to sync fpga with DDS clock and sample all inputs from DDS accordingly.
Reply by simonzz●February 27, 2021
If the DRG time base is fsysclock/24 yes, DROVER can be sampled.
If you mean fsysclock is the fpga sampling clock and that it is related to DDS clock then that is ok for clock speed but you still need the input to be synchronous and not violate tSU/tH even if it is much slower, unless you don't want synchronous input in which case all clock details become irrelevant. alternatively use/think of FIFO transfer from DDS domain to fpga domain as any dual clock system.
No, I meant DDS fsysclock as datasheet reports.
In my case the DRG timebase would be around 104 MHz (DDS fsysclock = 2500 MHz).
I am actually using an edge detector to synchronize DROVER to FPGA clock.
