RC-filter in VHDL
Started by Aida92 5 years ago2 replieslatest reply 3 years ago245 views
Hello everyone!
I am trying to implement Raised-cosine filter in VHDL. In the current simulation I am using the standard method of the filter simulation:
- create an array with filter coefficients
- add and mult
I would like to optimise the simulation.
Does anyone has an example how I can implement the filter? Is there another way to implement it?
Reply by kazFebruary 16, 2023
Hard to get details of your add-mult
There are ways to reduce any filter:
Either using LUT if input levels are few and fixed e.g. QAM. so mult results can be precomputed and inserted in a table to be addressed by input.
Or if upsampling/downsampling and filtering at same time then you can reduce resource a lot but requires good grasp of these concepts.
Or have a clock speed multiple of sample rate to share same resource across available clock ratio.
Reply by engineer68February 16, 2023
Optimize simulation or optimize real calculation and resource usage?
COS(x) can be calculated in real time or be approximated with polynomic equations if there is not enough RAM for the explicite values.
RC-like functions can be emulated with polynomes too, especially when using simple pulse shaping: parametric saturation functions
