cout in FPGA
Started by WCH 4 years ago1 replylatest reply 4 years ago103 views
Hello, I am new to FPGA. I have seen a template in DE0-nano. I would like to display the value in "PWM_width <= PWM_width[5:0]+ PWM_adj;" one by one in a screen like the cout function in C++
I used "%display()" but I didn't see the value in the message box in quartus. Thanks
module DE0_NANO(
//////////// CLOCK //////////
CLOCK_50,
//////////// LED //////////
LED,
//////////// KEY //////////
KEY,
//////////// SW //////////
SW,
//////////// SDRAM //////////
DRAM_ADDR,
DRAM_BA,
DRAM_CAS_N,
DRAM_CKE,
DRAM_CLK,
DRAM_CS_N,
DRAM_DQ,
DRAM_DQM,
DRAM_RAS_N,
DRAM_WE_N,
//////////// EPCS //////////
EPCS_ASDO,
EPCS_DATA0,
EPCS_DCLK,
EPCS_NCSO,
//////////// Accelerometer and EEPROM //////////
G_SENSOR_CS_N,
G_SENSOR_INT,
I2C_SCLK,
I2C_SDAT,
//////////// ADC //////////
ADC_CS_N,
ADC_SADDR,
ADC_SCLK,
ADC_SDAT,
//////////// 2x13 GPIO Header //////////
GPIO_2,
GPIO_2_IN,
//////////// GPIO_0, GPIO_0 connect to GPIO Default //////////
GPIO_0_D,
GPIO_0_IN,
//////////// GPIO_0, GPIO_1 connect to GPIO Default //////////
GPIO_1_D,
GPIO_1_IN,
//  PARAMETER declarations
//  PORT declarations
input           CLOCK_50;
output     [7:0]LED;
input      [1:0]KEY;
input      [3:0]SW;
output    [12:0]DRAM_ADDR;
output     [1:0]DRAM_BA;
output          DRAM_CAS_N;
output          DRAM_CKE;
output          DRAM_CLK;
output          DRAM_CS_N;
inout     [15:0]DRAM_DQ;
output     [1:0]DRAM_DQM;
output          DRAM_RAS_N;
output          DRAM_WE_N;
output          EPCS_ASDO;
input           EPCS_DATA0;
output          EPCS_DCLK;
output          EPCS_NCSO;
output          G_SENSOR_CS_N;
input           G_SENSOR_INT;
output          I2C_SCLK;
inout           I2C_SDAT;
output          ADC_CS_N;
output          ADC_SADDR;
output          ADC_SCLK;
input           ADC_SDAT;
inout     [12:0]GPIO_2;
input      [2:0]GPIO_2_IN;
inout     [33:0]GPIO_0_D;
input      [1:0]GPIO_0_IN;
inout     [33:0]GPIO_1_D;
input      [1:0]GPIO_1_IN;
//  REG/WIRE declarations
wire           reset_n;
reg [26:0] counter;
reg [5:0]   PWM_adj;
reg     [6:0]   PWM_width;
reg     [7:0]   LED;
//  Structural coding
assign   reset_n = KEY[0];
always @(posedge CLOCK_50 or negedge reset_n)
if(!reset_n)
counter <= 0;
LED[0] <= 0;
else begin
counter   <= counter+1;
if(counter[26])
PWM_adj <= counter[25:20];
else begin
PWM_adj <= ~ counter[25:20];
LED[0] <= ~PWM_width[6];
LED[1] <= ~PWM_width[6];
LED[2] <= ~PWM_width[6];
LED[3] <= ~PWM_width[6];
LED[4] <= PWM_width[6];
LED[5] <= PWM_width[6];
LED[6] <= PWM_width[6];
LED[7] <= PWM_width[6];
endmodule
Reply by PtorruApril 1, 2022
Hi WCH, have you found any guidance since your post?
