sampling 800mbps data in virtex 5QV
Started by nilendra 10 years ago●9 replies●latest reply 10 years ago●169 views
We are trying for a space radar application. For that from ADC need to receive data at around 760MHz.
Is it possible to achieve using rocketio ?
Reply by adamt99●March 2, 2017
I have designed several space fpga including the v5 you need to think about Adc choice what is the output format 760 MHZ fs is 360 MHZ of bandwidth to be processed. Most high speed space devices use multiple outputs to provide a lower data rate output.
Have you considered radiation. The perfomance of the adc etc
Adam
Reply by elliotxu●March 2, 2017
You should be able to find I/O speed for both differential and single-ended from datasheet. If your ADC output is differential, 760MHz may be doable. V7 FPGA can support differential DDR data rate up to 1.25+Gbps.
The seven series devices are not space qualified at the moment hence the need for v5qv part.
It is possible i have used v5qv and 3 gsps adc and dac but need careful component selection and design. It will not be cheap either think about $1 million usd per board cost by time you include NRE
Reply by nilendra●March 2, 2017
Thanks for replay.
v5qv is fixed. we are going to use this and diffrential I/O, need to finalise ADC.
Thanks for replay.
we didn't finalise the ADC part no. yet but I/O will be diffrential.
Reply by rajkeerthy18●March 2, 2017
760MHz - Do you mean sample rate ? Some converters (-45 to 85 Degree C) use standardized serial interfaces providing BW from ~300Mbps to 3+ Gbps. RocketIO/MGT is required. Finalize the ADC, that would finalize the interface. Start implementing in FPGA.
thanks for your suggestion.
yes it is sampling rate.
our project is in planning phase. we are trying to confirm ADC and related interface. we are going to use differential I/O.
You may also be interested in this link
https://forums.xilinx.com/t5/Xcell-Daily-Blog/How-...
Thanks,
It is good post and quite interesting.
