Reduce Phase of a filtered data set
Started by shaddoll 9 years ago3 replieslatest reply 9 years ago116 views
Hi :)
So when you filter data sets using moving average, median or any other filter, they produce some kind of shift and they cant properly follow the original data.
I work with dynamic data so i asked me if there any way to reduce the shift produced by the filter, i've heard about FiR and IIR filters and forward-backward filtering but i don't know how to compute them with time series.
Reply by Pierre_NowoAugust 31, 2017
Take a look at this: https://fr.mathworks.com/help/signal/ref/filtfilt....
The backlash of doing this on FPGA is that you have twice the resources needed for a simple filtering. What you can do is to keep the non filtered data with te same delays, which costs just few additional logic.
Reply by kazAugust 31, 2017
filtfilt doubles delay(&more) in physical sense but keeps phase for modelling in software. I don't know any other use of it.
Any signal is delayed through a filter. This is rule of God??
Reply by asserAugust 31, 2017
There is a special kind of filters called the minimum phase filters.
They have unlinear phase characteristic but their group delay is minimized. For example, if a FIR filter of the 32-th order has the group delay of 16 clock cycles,
then the same minimum phase filter has it of 7 clock cycles.
It is valuable for the real time systems with a feedback.
Of course, the forward-backward filtering does not fit the minimum group delay demands at all.
