register clear on read
Started by kamalovich 7 years ago4 replieslatest reply 7 years ago2652 views
Summary This discussion focuses on the definition and implementation of 'clear on read' registers in VHDL, specifically for Bit Error Rate (BER) monitoring.
This discussion focuses on the definition and implementation of 'clear on read' registers in VHDL, specifically for Bit Error Rate (BER) monitoring. The thread explains that these registers automatically reset to zero immediately after being read by a host processor.
The consensus provides a logic-based solution where a read-acknowledge signal acts as a synchronous reset for the counter. This ensures that statistics like error counts are cleared for the next measurement period without requiring a separate write command.
  • A clear on read register resets its value to zero when accessed by a host read operation.
  • Implementation involves using the address-decoded read signal as a synchronous reset for the register logic.
  • This behavior is commonly used for status registers, interrupt flags, and hardware statistics counters.
  • Care must be taken to 'OR' the read-clear signal with the global system reset in the VHDL process.
VHDLDigital Logic DesignHardware Registers
hi all !
I am doing a BER (BIT ERROR RATE) in vhdl and I have to put 2 registers clear on read which counts the number of words in error and the number of bits in error. i want to know what is a register clear on raed and how i can code a register clear on read in vhdl?
thank you,
Reply by martinthompsonJune 11, 2019
Clear on read means that when the host processor reads the data from your peripheral, the registers should reset themselves to zero.
Within your bus interface block you will have some logic which multiplexes the registers out to the databus when a read happens, based on the incoiming address.  The logic that manages that can be used to create a single-cycle signal, one for each register, which you can use as a synchronous reset on the registers in question.  If you already have a sync reset you can 'or' this new signal in (assuming active high reset):
process (clk)
  if rising_edge(clk) then
     if reset='1' or i_was_read_by_the_host='1' then
         reg_value <= (others => '0');
etc...
Reply by kamalovichJune 11, 2019
thank you all is clear now!
Reply by rajkeerthy18June 11, 2019
When read signal is active register is reset to "0" and read_bus <= register_val. Status registers, interrupt registers, statistics counters are implemented this way.
thank you!
