BRAM based FIFO
Started by maha_66 8 years ago3 replieslatest reply 8 years ago2923 views
Summary A user inquired about how to implement a FIFO using Block RAM (BRAM) for an Artix-7 matrix multiplication project, questioning if a BRAM-inference code snippet automatically functions as a FIFO.
A user inquired about how to implement a FIFO using Block RAM (BRAM) for an Artix-7 matrix multiplication project, questioning if a BRAM-inference code snippet automatically functions as a FIFO. The discussion clarifies that while a FIFO uses BRAM for storage, additional control logic is required to manage read/write pointers and status flags.
The consensus recommendation is to use the Vivado IP Generator to create a FIFO core or to manually instantiate Xilinx primitives rather than relying solely on generic BRAM inference for FIFO functionality.
  • BRAM inference code provides memory storage but lacks the necessary pointer logic to function as a FIFO.
  • Using the Vivado FIFO Generator IP is the recommended approach for creating reliable buffers in Xilinx designs.
  • A FIFO can be configured to use either BRAM or Distributed RAM resources depending on implementation requirements.
  • The Xilinx 7 Series Libraries Guide (UG768) provides specific templates for instantiating hardware-native FIFO primitives.
VHDLXilinx VivadoBRAMFPGA Hardware
Hello! I am currently working on a matrix multiplication project. After performing the multiplication of the matrices, I am trying to build a module that can write to memory and can be read from by the UART TX module to send to host pc. What I don't understand is how does inferring a BRAM make it function as a FIFO? Do I need a separate module for a fifo buffer unit? The VHDL book I use has a sentence that I am not sure I understand completely: "Infact, the BRAM module of the Artix device can be configured as a FIFO buffer without any extrernal logic."
I have the following code for inferring a Simple(Sync) Dual Port BRAM for the Matrix Result:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity bram_simpledual is
generic( ADDR_WIDTH: integer := 4;
         DATA_WIDTH: integer := 16
  Port (
            clk : in std_logic;
            we : in std_logic ;
            addr_r, addr_w : in std_logic_vector (ADDR_WIDTH - 1 downto 0);
            din_a : in std_logic_vector (DATA_WIDTH - 1 downto 0);
            dout : out std_logic_vector (DATA_WIDTH - 1 downto 0)
end bram_simpledual;
architecture beh_arch of bram_simpledual is
    type ram_type is array (0 to 2** ADDR_WIDTH - 1) of std_logic_vector (DATA_WIDTH - 1 downto 0);
    signal ram: ram_type;
    process(clk)
        if(clk'event and clk = '1')then
            if(we = '1')then
                ram(to_integer(unsigned(addr_w))) <= din_a;
            end if;
            dout <= ram(to_integer(unsigned(addr_r)));
        end if;
     end process;
end beh_arch;
Reply by rajkeerthy18July 6, 2018
The above code would infer a memory (BRAM if you are targeting Xilinx) with write and read logic but NOT a FIFO. If you need a FIFO in the design, a FIFO could be created from the tool and the wrapper generated by the tool could be instantiated in your design, which is a safe approach. The tool could generate a BRAM based FIFO or Distributed RAM based FIFO depending on your customization. FIFO primitive is available for manual instantiation in some Xilinx families, please check the appropriate family HDL library.  You could also manually instantiate BRAM and design remaining FIFO logic around it. I personally prefer to manually instantiate than infer any memory. To mention, if a particular component is not connected to module port or not connected to any logic that connects to port, in other words if a component is not viewed as a dependency from the perspective of module port, such component would be removed (optimised) from the netlist by the tool.
Reply by apanellaJuly 6, 2018
If you are using Vivado (which you should be, for an Artix FPGA), then you can add a FIFO to your design by creating an IP block design and adding a FIFO. From there, you can edit the FIFO IP block and customize for your purposes. Make all connections external, validate design and then make an HDL wrapper, which is a VHDL module which can then be instantiated in your design and then you can access the FIFO as needed.
Now, the FIFO IP block in terms of hardware is inferred with the use of a BRAM. If you put a FIFO in your design and it is not being optimised out, you can observe this by synthesising, implement design and then open implemented design, and then use the tcl command 'report_utilization'. Scroll to the BRAM section and you will see that your FIFO does indeed use some BRAM.
You can also explicitly instantiate primitives such as a BRAM18 etc. manually, which is closer to what you have in your example code.
So in summary; instantiating a FIFO will infer a BRAM.
Reply by oliviertJuly 6, 2018
Hi
have a look to the UG768  "7 series FPGAs Libraries Guide"   p60
You'll have the template to instantiate the right FIFO.
Olivier
