Tips for using Xilinx Ultra RAMs
Started by 7 years ago●2 replies●latest reply 7 years ago●3915 viewsThis discussion outlines the functional differences between Xilinx UltraRAM (URAM) and traditional Block RAM (BRAM) for UltraScale+ architectures. While URAM offers significantly higher density at 288k bits, it lacks certain BRAM features such as asynchronous clocking, dedicated FIFO logic, and true dual-port flexibility.
- URAM is a single-clock synchronous memory and does not support asynchronous dual-port operations.
- Unlike BRAM, URAM does not have dedicated FIFO logic and must be used in RAM-only mode.
- The dual-port behavior is restricted: Port A operations complete before Port B, and write operations do not update read outputs in the same cycle.
- Vivado can infer URAM from RTL code, though the blocks are less flexible than standard 36k BRAMs.
What are the main considerations that I should be aware of if I want to use Ultra RAMs in my design?
I am familiar with the Block RAMs used in 5-, 6- and 7-series Xilinx devices. As far as I am aware, the BRAMs in Ultrascale and Ultrascale+ devices are similar to 7-series: 36k, true dual port, asynchronous, built-in FIFO logic.
However, I'm interested in what's different about URAMs. As far as I can see, they are 288k, true dual port, but synchronous and with no dedicated FIFO logic. (So 8x as deep, but similar r/w interfaces to a BRAM, albeit with a single clock?). It also seems like they cascade together efficiently across the whole device, so you can get extra deep (or wide?) RAMs with good timing performance without using much of the general FPGA fabric.
What are the other main differences?
Do the tools (Vivado) infer URAMs sensibly from general RTL code?
What other implementation considerations are there? (e.g. number of pipelining registers on read ports).
Ultraram is in ram only mode and no fifo mode available. Single clock (not an asynchronous memory) 2 ports but not a true dual port. Synthesis infers ultra ram. Fixed behaviour, Port A operation completes first. Programmable latency. Interesting block to design with not as flexible as block rams.
2 ports but not a true dual port... Fixed behaviour, Port A operation completes first.
Ah yes, thanks for the correction. It seems like the URAM dual-port behaviour is slightly restricted compared to true dual-port BRAMs. In many use cases, I can see this "Port A then Port B" operation will not be a problem. However, I also notice in the Xilinx docs that "Each port can only execute either a write or read operation in one cycle. When executing a write operation, the read outputs are unchanged and hold the previous value." I can imagine some scenarios where this would be an interesting challenge to manage.
Could you say something more about this? I can't see the relevant info in the Xilinx docs. Is read latency ≤ 2 clock cycles like with BRAM?
Absolutely. I hope I get a chance to soon :)
